Overheat protection for the heater: second sensor, KSD, and firmware limits
If there’s an option to install two sensors and monitor two parameters at once, then why not do it? Monitoring the heater temperature lets you avoid local overheating around the heating element while still giving the maximum heating speed within the limits. You can do without it, but why?
Если есть возможность поставить два датчика и контролировать сразу два параметра, то почему не сделать этого? Контроль температуры нагревателя позволяет не создавать локальный перегрев в области грелки, при этом обеспечивая максимальную скорость нагрева с учетом ограничений. Можно и без этого, но зачем?
Damn, I’m actually all for not overheating the heater, and that’s exactly the main job of the sensor on the heater itself (accurate temperature control is more of a bonus, in my opinion).
But this sensor is attached to the heater in a pretty bad way, maybe that’s why there were reports of melted housings.
Блин, я как раз за то, чтоб не создавать перегрев грелки и это как раз главная задача датчика на грелке (точность контроля температуры это, на мой взгляд, уже бонус)
Но вот прицеплен этот датчик на грелку не очень удачно, может именно поэтому и были сообщения о поплавленных корпусах.
Here’s the thing: you’ve got an open system, you can assemble it and tweak whatever you want however you want, and print the housing from whatever you have, so the whole group is really about thinking first and then doing. And there are a lot of ways to mess things up, which is why there are limits in the firmware — but you can change them however you like, and that can either improve things or make them worse, depends how it goes. As for things melting — yeah, I’ve seen the end opposite the heater wire exit melt on other people’s units, and I ran into it myself too. But in my case it was under extreme conditions while testing, and I think people were pushing theirs hard too, but who’s gonna admit that.
I already wrote about the housings, but these really are two separate tasks, and safety was easier to solve not algorithmically but just by slapping in a 110C KSD like the Chinese do.
суть в чем, у тебя открытая система, ты можешь собрать и накрутить что и как тебе нравится да и корпус напечатать из чего есть, так что группа реально про сначала подумать потом сделать, а вариантов накосячить прям много, потому ограничения в прошивке есть, но ты же можешь их поменять как тебе нравится и улучшить этим или наоборот испортить, это уже как получится. По плавится да, торец противоположный выходу проводов из грелки видел у людей и сам встревал, но я встревал на экстремальных режимах, когда тестил, думаю и люди тоже разгоняли, но кто же скажет
про корпуса написал уже, но реально это две независиыме задачи и безопасность было проще решить не алгоритмически и тупр поставив ксд на 110С как это делают китайцы
That fuse is the last line of defense when something has already gone wrong.
Definitely a necessary thing, but the main control should be in software.
Этот предохранитель - он уже последняя надежда, когда что-то пошло не так.
Вещь безусловно нужная, но основной контроль должен быть на программе.
Nah! You’re wrong here! For the Chinese, that’s a thermostat!
ну нет! тут ты не прав! у китайцев это терморегулятор!
Alright, let’s leave the Chinese “engineering” solutions out of this discussion. A thermal fuse is an emergency safety component; overheating control belongs on the thermistor and in the firmware.
Так, “конструкторские” решения китайцев оставим за рамками обсуждения. Термопредохранитель это аварийная часть, контроль перегрева на терморезисторе и прошивке.
Actually, the docs say that KSD is better to use during the initial setup, and then after that install an actual fuse, because during the initial setup you can burn through quite a few of those fuses)
Just read the docs and use the solutions that are actually safe)
https://t.me/iDryer/42355/84685
на самом деле в доке написано что ксд лучше использовать при первичной нстройке а потом поставить именно пред, потому что при первичной ты этих предов можешь упалить много)
тока читай доку и применяй те решения которые прям безопасны)
My ability to do the initial setup is pretty limited, since a standalone mode is planned.
У меня сильно ограничена возможность первичной настройки, потому как планируется стэнделон режим.
That’s a special case, but I’m writing the docs for everyone.
What printer is it for?
это частный случай, а доку я пишу для всех
на какой принтер?
I don’t know,
I haven’t dealt with Klipper, and there’s no reason for me to mess with it now at all.
So the goal is standalone, and if the firmware says, for example, that the heater limit is 90, then I want that to work and to be as reliable as possible, that’s all I need.
Не знаю,
Я с клиппером дела не имел и резона сейчас с ним заморачиваться вообще нет.
Поэтому цель - стэнделон, и если там будет написано в прошивке скажем ограничение грелки 90, то чтоб оно работало и максимально надёжно, больше мне не нужно.
