Loss of connection to the iHeater MCU: what to check besides the USB cable
What could be causing these dropouts?
It worked for a week, but today it’s driving me nuts with errors.
Lost communication with MCU ‘iHeater’
Once the underlying issue is corrected, use the
“FIRMWARE_RESTART” command to reset the firmware, reload the
config, and restart the host software.
Printer is shutdown
Эти вылеты с чем могут быть связаны?
Неделю работало, сегодня прям задолбало ошибками.
Printer is shutdown
I think you need a shorter cable, and it’d be better to solder it instead of using connectors.
мне кажется, надо брать кабель покороче и лучше спаять, а не на разъёмах.
What exactly should I solder, and what does UART have to do with it?
It’s connected with a regular USB cable.
I already swapped the wires.
What else could it be?
Что паять и при чем тут uart?
Подключение обычным кабелем usb.
Провода менял.
Что еще может быть?
I thought the heater had USB pads on it. But nope. So only to the printer board then. On the K1, at least, you can solder all the USB directly to the board. Ignore the UART part, that was just me thinking out loud about how USB is implemented on the F042.
I also raised the Heater higher off the floor and routed its 220V power separately from the printer.
Something out of that worked. Before that, the errors were coming in nonstop.
А я думал, на хитере есть площадками УСБ. А нет. Значит только к плате принтера. У к1 во всяком случае все УСБ можно подпаять напрямую к плате. На юарт не обращай внимания, это так, мысли вслух были по поводу реализации УСБ на ф042
Я ещё Хитер повыше от пола поднимал и его питание 220 отдельно от принтера выводил.
Что-то из этого сработало. Так ошибки прям валом валились.
I had some adventures trying to make shielding for the USB wires in the printer using its standard grounding, without actually having that grounding in the wall outlet. But in my case the cartographer was disconnecting when the iHeater fan turned on. It was all fixed by removing all the non-standard shields and grounding I had made.
I’ve never had the iHeater disconnect even once.
у меня были приключения с попытками сделать экранирование для usb проводов в принтере на основе его стандартного заземления без наличия этого самого заземления в розетке. но там отваливался картографер при включении вентилятора iheater. решилось все отключением всех нестандартных экранов и заземлений, которые я сделал.
отвалов iheater у меня не было ни разу
The house is new, grounding is there as standard.
The printer and iHeater are connected through an online UPS; in ECO mode it’s on bypass = directly from the mains, each with its own cable.
There were no power spikes, and I’ve never noticed any issues even when powered through the UPS inverter.
I changed the USB cables.
Today alone the error popped up 4 times and ruined the print.
Дом новый, земля есть по стандарту.
Принтер с айхитером подключены через ИБП онлайн, в режиме ЭКО он на байпасе = напрямую от сети, каждый своим кабелем.
Скачков не было, да и при питании через инвертор ИБП проблем не замечал никогда.
Провода USB менял.
За сегодня 4 раза ошибка выпадала запарывая печать.
What do the logs say, any attempts to reconnect to the MCU?
а логи что пишут, попутки соединения с mcu?
I still haven’t learned how to read them. What am I even supposed to look at there? It’s a mile-long wall of text.
Я так и не научился их смотреть. Что там смотреть? Там портянка километр.
Just clear them out, they keep everything for ages, or just look at the bottom.
ты их сноси, они за кучу времени всего хранят, или просто внизу смотри
I don’t understand what I’m supposed to look for there.
Is there some kind of manual on how to read the logs, what everything in them means?
Is this it?
Timeout with MCU ‘iHeater’ (eventtime=3328.009947)
Transition to shutdown state: Lost communication with MCU ‘iHeater’
Я не понимаю что там смотреть.
Есть где то мануал как читать логи, что где в них значит?
Это оно?
