iHeater firmware runs from a prebuilt binary, but my own build won't flash
xub@xub-HM570:~$ python3 ~/katapult/scripts/flashtool.py -d /dev/serial/by-id/usb-katapult_stm32f042x6_12002D000C53304B4D323431-if00 -f ~/klipper/out/klipper.bin
Connecting to Serial Device /dev/serial/by-id/usb-katapult_stm32f042x6_12002D000C53304B4D323431-if00, baud 250000
Detected USB device running Katapult
Detected Klipper binary version v0.13.0-395-gf04895f5, MCU: stm32f042x6
Attempting to connect to bootloader
Katapult Connected
Software Version: v0.0.1-109-g902f335
Protocol Version: 1.1.0
Block Size: 64 bytes
Application Start: 0x8002000
MCU type: stm32f042x6
Flashing ‘/home/xub/klipper/out/klipper.bin’…
Write complete: 14 pages
Verifying (block count = 213)…
Verification Complete: SHA = D5B57ACA24CDBC633834F39E119A54EE771436B2
Programming Complete
xub@xub-HM570:~$ cd ~/klipper
xub@xub-HM570:~/klipper$ git describe --tags
I installed everything from scratch. Klipper is the latest version. Now all the parameters in the firmware config match. This time it flashed without any issues. But the board disappeared from lsusb. I’m out of ideas for now.
Got it working! I dropped in a ready-made firmware, the closest match, 0.12.0-420, from here: https://github.com/pavluchenkor/iHeater/releases/tag/klipper
Katapult Connected
С чистого листа всё поставил. Клиппер последней версии. Теперь все параметры в конфигурации прошивки совпадают. Теперь прошилось без проблем. Но в lsusb плата пропала. Пока идей больше нет.
Получилось! Подкинул готовую прошивку наиболее подходящую 0.12.0-420 отсюда: https://github.com/pavluchenkor/iHeater/releases/tag/klipper
Well, looks like the little script came in handy after all)
Ну вот и скриптик сгодился)
But I still don’t understand what the problem is with compiling on my side
Но так я и не понял в чем проблема в компиляции у меня
Can’t help there, I’m barely holding on… haven’t slept, the weather’s crushing me, brr…:face_with_head_bandage:
I compiled all this in wsl
не подскажу, не отпускает… не спал, погода давит, бр…:face_with_head_bandage:
я это все в wsl компилировал
I’d do it through a VM too, but my processor is a mutant
Я б тоже через виртуалку делал, но процессор мутант
