BME280 on iDryer won't start because Klipper can't see the I2C bus
Looks like I replaced all the STH3x entries with BME280, but it still won’t start.
[temperature_sensor iDryer_U1_Air]
sensor_type: BME280
if your iDryer is used as a second MCU uncomment:
i2c_mcu: iDryer
i2c_bus: i2c0f
i2c_address: 118
i2c_software_sda_pin: gpio20 #second HW version - green PCB | i2c_software_sda_pin: gpio18 #first HW version - red PCB
i2c_software_scl_pin: gpio21 #second HW version - green PCB | # i2c_software_scl_pin: gpio19 #first HW version - red PCB
Вроде все STH3x заменил на BME280, но всё равно не заводится
sensor_type: BME280
i2c_mcu: iDryer
i2c_bus: i2c0f
i2c_address: 118
It says the I2C bus is unknown.
No idea why Klipper doesn’t want to see the bus. Comment out the bus, and uncomment the software pins.
Оно говрит что i2c шина неизвестная.
Хз почему Клиппер не хочет шину видеть. Шину закомментируй, а пины сгфтвверные раскомментируй.
