Were can I purchase a iDryer Unit MCU+EXT Kit?
I want to buy a iDryer Unit MCU+EXT Kit ? Where can I get a list of dealers?
Thanks!
Bob East
@beast3
Hi, Bob! You can buy the kit at the iDryer store.
And when will the 220-volt be available?
I would but it has been out of stock for quite a while.
@beast3
I’m working on it :wink:
The 220-volt availability seems tied to the same supply issue as the MCU+EXT kit, since @beast3 mentioned working on it. Given the kit has been out of stock for a while, is there any sense of whether the restock and the 220-volt version will land around the same time, or is the voltage model further behind? I’d rather wait for the 220-volt if the timeline is close, but if it’s a long way off it changes which one I’d go after. Also worth asking whether the kit itself is voltage-agnostic and only the power side differs.
The voltage-agnostic question seems key: if the MCU+EXT kit only differs on the power side, then waiting for the 220-volt model may not gain you much beyond the supply chain timing. Until @beast3 gives a clearer signal on whether restock and the 220-volt version will land together, it’s hard to judge whether waiting makes sense. If the kit is compatible across voltages, that would make the decision easier for anyone weighing both options.
