The portal moved to a new version today. Below is only what you will actually notice.
Chart storage is now predictable. Every account has a storage allowance for telemetry. As it fills up, the portal tells you in advance how much is left. Charts from finished drying runs are thinned out automatically — the shape of the curve is preserved, the space is freed. There is now a button to free up space yourself.
Home Assistant no longer competes with your printer. Turning Home Assistant on used to switch Moonraker or Bambu off, taking the printer data with it. They now run at the same time. The either-or choice remains only between Bambu and Moonraker, because a device has a single printer.
Give the integration settings a try — Moonraker, Bambu Lab and Home Assistant are configured from the device card.
Devices show that they are online faster.
A summary for every drying run — how much moisture was removed, plus average, starting and finishing temperature.
The web flasher has moved to a new way of binding. No more PIN: you sign in right on the flashing page, and the device is bound over the cable. Firmware is available for every supported board. The same will work over the air and in the app once the new version is published.
Spool QR codes and portal links now open the iDryer app directly instead of the browser.
I did my best to keep compatibility with older versions.
If something stopped working — update your device firmware. Later updates will arrive over the air.
The storage allowance explanation is useful, but I’m curious how thinning affects very short drying runs where the curve has little data to begin with. Does the portal keep the raw starting and finishing points intact even after thinning? Also, the summary metrics for each run sound handy, though I’d want to know whether they’re recalculated after thinning or stored separately. The point about Home Assistant and Moonraker running at the same time seems like a welcome fix for anyone pulling printer data alongside sensor readings. Updating firmware first makes sense before judging what broke.
The portal runs on a sponsor’s resources, and they are not unlimited. That is why old charts are thinned: redundant points are removed without any noticeable loss of information.
Thinning only applies to runs that finished more than 7 days ago. The last 7 days are kept in full.
The first and last points of every series are always kept, and a run with two points or fewer is not thinned at all. On a short, flat run you keep the endpoints plus any point that deviates from the line between its kept neighbours by more than the threshold:
temperature: 0.3 °C;
humidity: 0.5 %;
heater temperature: 0.5 °C;
heater power: 10 %;
weight: 1 g.
Run summary metrics (start and end temperature, average temperature, humidity drop, weight before, aftergy) are calculated once when the run ends, from the fule session. They are notrecalculated after thinning.
Some users felt the device was sending data to the portal too often, so I reduced the rate. In practice there is now too little data, so an upcoming update will send data on a similar principle: when temperature, humidity, power or another value changes by more than a threshold, the data is sent right away, regardless of the interval.
