So, iDryer team, shall we have some fun)
while there’s still no iDryer W thread, I suggest discussing it here
I’m trying to cobble something together with my left hand)
a standalone board with wifi as an alternative to both X and Unit
there are several options for the basic functionality that affect the final cost
base: esp32s3, 12V fan, 220V 100W heater, scales
all of this, as intended, comes with some kind of basic firmware, gets configured by the user, and updated to the main firmware
fits into X and Unit size-wise. pin2pin compatible -
extra: this is where it gets tricky! even though it seems like a small thing, it can turn into 6-8 bucks. what am I talking about… the ability to reflash it in case of a failure, and that means a usb connector, tvs diodes, a cp2102 converter, supporting circuitry… basically it all costs money, and it’s really not needed that often, only in some kind of emergency.
so the question is, is it worth spreading that across the board and raising the price, or if something goes wrong should the user just buy a programmer and flash it directly?
it’s kind of all there in KNOMI, but I’m afraid that if I pile things on, I won’t fit into the KNOMI price, because there it’s just a little screen, while here there are scales, the power section, PSU, basically everything all at once…
any opinions are welcome and all of them will be heard
anything off-topic will be deleted (admins
) within 24 hours so we don’t lose focus
Ну что, команда iDryer, пошалим)
пока еще нет темы iDryer W, предлагаю обсудить тут
я пытаюсь что-то левой рукой ваять)
плата standalone с wifi как альтернатива всему и X и Unit
есть несколько вариантов базового функционала влияющего на итоговую стоимость
база: esp32s3, кулер 12В, нагреватель 220В 100Вт, Весы
все это по замыслу приходит с некой базовой прошивкой, конфигурится пользователем и обновляется на основную прошивку
лезет в X и Unit по габаритам. pin2pin совместимо -
extra: вот тут сложна! при кажущейся мелочности вопроса он может вылиться в 6-8баксов. о чем речь… возможность прошивки в случае аварии, а это разьем усб tvs диоды конвертор cp2102, обвязка… короче все стоит бабла а нужно далеко не всегда, вернее в каком-то аварийном случае.
и вот вопрос, стоит ли это размазывать по плате и поднимать стоимость или в случае аварии пользователь сам купит программатор и прошьет напрямую?
оно вроде как все у KNOMI, но боюсь, если наворачивать, в цену KNOMI не пролезу т.к. там просто экранчик а тут и весы и силовая часть и бп, короче всего до кучи…
приветствуются любые мнения и все они будут услышаны
все вне обсудения темы будет сноситься(админы‼️) в течении суток дабы не терять фокус
